Serial number = 0m345217
Some Background... Because of a small oil leak in the back of the intake manifold, I removed the intake manifold and replaced the gaskets.
I ran it after the repair on muffs and it ran great at idle and at higher RPMs.
Put the boat into the water today. It idled fine and put the boat into gear and it ran fine util I got above 1300rpms when it started hesitating and sputtering. If I went back below 1300rpms it ran fine again. If the engine is not under load it runs fine. Any help is appreciated!!.
