2002 mercury 150 dosent have leg gear oil drain plug dosent exist! ?
kell 9
hi i am new here but i whent to change my leg oil and there is no srain bolt i have looked over and over again the only thing i can think of is that someone welded it in.... what do u guys think . thank you for your imput
Mi duckdown
Re: 2002 mercury 150 dosent have leg gear oil drain plug dosent exist! ?
I think you need to post a serial number. and pic of motor and lower end.????
kell 9
ok i will in a few days . could it be in a difrent spot then most motors thx for your hellp
Mi duckdown
I don't think so.???
carholme
Kell;
I'm sure you have checked but from the service manual I sent you the other day, in the Lower Unit section, Right Hand, Page 6A-13 or Left Hand, Page 6B-14, you will clearly see where the fill/drain plug is. I am not sure of your experience but the plug you see identified as the Fill plug is also the Drain Plug.
Gerry
jerryjerry05
You don't give any info on model serial# etc.
It could be under the prop in the bearing carrier.Mercury Outboard Parts 200 PRO XS (DFI) 3.0L 1B504989 & Up Boats.net Jerry
carholme
It's an EFI as you will see from his previous posts.
Gerry
Faztbullet
The only unit that would have drain in the carrier is the torquemaster case and these where only on the Hi-po motors. I have seen people JB weld over the screw if the threads where slighlty stripped but you could seen outline of where it was filled in.
jerryjerry05
Gerry,I need to check his previous posts??He should have included it in his initial post.U seem to have a problem with me posting.Something wrong?
I'm on here trying to help.I never criticize ANYONE even though some are the biggest dummies and some suffer from CRI.Jerry
kell 9
hi and thx for all your guys hellp my boat is not at my house so i cant get the number right away but i look in the manul and my drain plug isent where it is in the manul
carholme
Kell;
Please let us know the next time you get a chance to look at the engine.
If there isn't one there for whatever reason, a good machine shop in your area could install one for you and when the lower unit is disassembled, you would be able to have a good look inside to see if you can find where someone has filled it in.
I presume that the engine has had a previous owner, has he not been able to tell you what happened?
Gerry
