2002 mercury 150 salt water efi compression ?
kell 9
what should a 2002 mercury 150 salt water efi be when new? thank you
JB
Re: 2002 mercury 150 salt water efi compression ?
There is no spec on psi. All cylinders should be in a 10-15% span. There are too many variables to set a spec on psi.
If all cylinders compress within 10% of each other it is very unlikely that any are bad.
kell 9
cool thank you
