jonnysteals
Thread starter- Joined
- May 26, 2009
- 56
MY engine mount on my 2002 suzuki df140 corroded a hole in the exahsut port. I am replacing this myself in my garage. I pulled the powerhead and removed the engine mount. MY issue is with the engine mount shift linkages. I ahve attached images so you can see my issues.
On my original engine mount I had one bearing which housed the engine shaft which powered the propeller. The shift linkage bolted in from the bottom. See pictures mount1 and mount2.
The new engine mount they sent me has tp bearings. One for the propeller and one for the shift linkage. They eliminated the screw part from the bottom and it looks like its now sealed with o-ring or someting like that. See picture mount4.
My boat is the palm beach picture I also attached.
My question is did suzuki redesign the shift linkage after my 2002 model year to entend the gear selection(foward,neutral, and reverse) threw a bearing into the motor mount? How can I upgrade my older motor to use this system? If they didn't upgrade would it be possible that they sent me the wrond engine mount.
Here is the mount I ordered
http://www.boats.net/parts/search/Suzuki/Outboard/2002/DF140/ENGINE HOLDER/parts.html
Heres the one I received:
http://www.boats.net/parts/search/S...ER (DF140T:682149-,DF140Z:680234-)/parts.html
The only difference is that the one with two bearing has a t in the model number. I beleive that is the counter rotationg one. Should I have them ship me one that can bolt to the bottom like I had or upgrade my shifting parts? All help is appreciated
