2002 Yamaha F100 4 stroke weak coil?
Status
Not open for further replies.
usedcarman
Hi Folks,
Bought this boat last fall, came with a 2002 Yamaha F100 4 stroke carburated engine, when i got it started this spring, it was misfiring on #4 and seemed to have very weak spark, seemed to be running on 2 or 3 cylinders, but specially bad on number 4. But it always starts up fine. Swapped plugs with #3 with no success, did a compression test which came up good 120psi to 150 psi. Pulled plug wire while running on #4 with almost no change, tried with #3 it then stalled. Next I swapped coils, top coil was running #1 and #4, bottom coil was running #2 and #3, unplugged them completely including unplugging the feed wire and swapped them, now #4 and #1 run good and #3 runs poorly as well as #2, am I right into thinking that I have a weak coil? How do I make sure that it is the coil that's the problem? How do I test it before purchasing another one, because once purchased electrical parts cannot be returned.
Any help would be greatly appreciated!
99yam40
Re: 2002 Yamaha F100 4 stroke weak coil?
A Yamaha service manual will give specs and make sure you use the proper test equipment like the manual states.
Normally ohm test should show if it is bad, but voltages in and out would be a sure thing for trouble shooting, not just looks weak.
Look for Sparkieboat's posts, he has some links at the bottom of his posts that will lead you to some good info on trouble shooting ignitions
Ander331
Thanks Captain! Will do! Much appreciated!
So what ended up happening?? I have same thing going on currently. Pull plug wires 1 or 4 while idling with very little change, but 2 or 3 plug wires it noticably wants to die.Tried a buddies coils and same thing. Runs a little rough at idle, but great with a little throttle up to about 5100 rpms then intermittently drops cylinders. Not like a bog but instant jerky loss of power and then it comes back. Also tried a different CDI with no change. Any help with this would be greatly appreciated!
MOD EDIT: Please review the forum rule about posting to old threads and feel free to start your own thread about your issue. This thread is 11 years old.
Status
