2002 Yamaha F115 runs fine for a while and then starts to backdown
Jeffsam1017
2002 Yamaha F115 runs fine for a while and then starts to back down. I can shut it off and it will run fine again for a little while and then starts to bog down again. It has progressively gotten worse. After doing a little research I suspect a clogged VST any ideas before I start taking it apart?
Thanks!
99yam40
air leak into the suction line or a restriction could cause this.
tank vent clogged is the 1st thing to check.
then monitoringfuel pressures and vacuum to help identify the problem
