robsalik24
Thread starter- Joined
- Oct 2, 2018
- 11
I am at my wits end here. I was out on the lake and the boat stalled and I couldn't get started. Pulled the plugs cleaned them went back on the lake motor got hot put it in neutral after a good 20 minute jog and it stalled. Let the motor sit for about a good hour and a half and fired back up. I have replaced the impeller the thermostat the popit valve clean the carbs and rebuild the fuel pump. Motor has less than 70 hours on a rebuild. Now it starts really hard have to choke the crap out of it. when it does run it does fire back up after it's been shut off once the motor's warm. But seems to have developed a miss or something. While the motor is on earmuffs I get a temperature about 110 to 120 out the telltale. I can also pull the number one and number three plug wires off and the motor will not stall. Same with the number two and number six. No change in tone or drop in idle.
