2003 150 z150txrb lower unit
mycobia21
Im trying to disassemble my lower unit due to water damage. Figured I would take it a part and see if it was economical to repair before buying a new one. I was able to get the bearing carrier out but the prop shaft is stuck and will not come out. looks like the thrust washer on the inside is corroded to the lower unit housing. Maybe I am missing something. Any suggestions would be helpful. the system would not let me attach pic I will try again from another computer
jbuote
Hey there! :welcome:
Lot's of great pro's here to help you out on that! (Wish I was one of them.. lol)
As for the pics, you need 3 posts to be able to post pics, then they need to be 700kb in size or smaller.
I've have best luck with pics ~400kb or so..
Here's a link to the photo tutorial for the forum in case you need it:
https://forums.iboats.com/forum/forum-rules-and-guidelines/10524592-photo-tutorial-dec-2017-update
Hope it helps, and I'm sure you'll find all the help you'll need from the great folks here! :)
mycobia21
This is a pic inside the lower unit housing after bearing carrier came out using puller and some heat
