2003 175hp Johnson Looper plug?
mboy
What is the different e running Champion QL82YC vs QL8YC in this engine?
I believe it says to run the QL78YC, but I have some QL82YC and was wondering if their is an issue running them on this motor.
i believe my marina (where I purchase 80% of my fuel) has 89 octane.
Very little trolling, mostly 3800 rpm cruising.
Thanks.
mboy
Re: 2003 175hp Johnson Looper plug?
BUMP for the safety of using QL82YC in my 2003 175hp 2-Stroke V6 looper?
angus63
I use QL78YC in my oceanpro (it's latest recommendation from OMC). Originally called for QL77JC which I'm told run a bit cooler. I would assume the QL82YC would run a bit hotter. In my opinion I would avoid anything that raises combustion temps above factory recommendation.
OMC recommends 87 octane fuel. You are using fuel that burns slower with a plug that is hotter than recommended. Not sure of the affect, but why chance it?
Good luck
