2003 8hp Merc...trying to find high altitude jets
aaarneson
Trying to find the correct jets for 6000 to 8000 elevation.
Ran at about that elevation this weekend and hardly any power compared to 1500-2000 elevation that runs at about 18mph.
SN: OT618494
aaarneson
Also I have a 3 blade prop and a 4 blade. The 4 was in at this high altitude....would the 3 blade be better?
Fun Times
SN: OT618494
You generally tend to find the altitude info inside a service manual for your engine model…, Here would be the part number you’d need… Maybe try searching the part number online to see if there’s a copy online already. https://www.mercruiserparts.com/827242r02-sm-o-b-6-15-2s
roscoe
3 blade or 4 blade means nothing without knowing the pitch of each.
any mercury dealer should have them.
The correct jet will balance the air/fuel mixture, and aid in running, but you will still experience a loss of power due to the air up there.
probably loose 1/2 of your power at 8000.
a properly jetted 15 hp is what you need.
jimmbo
Jets are not an item most dealers keep in stock(unlike spark plugs, they rarely need changing). If available, they can order them
airshot
Usuall they drop a couple inches of pitch when they move to a 4 blade prop, check yours...if same pitch or higher than the 3 blade, then you hurt your power output.
