txbandit44
Thread starter- Joined
- May 11, 2008
- 182
So new to me motor. Guy said it needed the carbs cleaned to run well. I planned on doing that and new impeller any way so I opted not to try and start it just did a compression test and got 120-120-120. He said it started running rough and he found out that since it has oil injection you don't have mix the oil in the gas!!!
So the question is Knowing this what should I do moving forward? Obviously rebuild carbs, new plugs and go though the lower unit. Do I do anything else? Or start there and see what happens. Never had one that had too much oil run through it.
