dumbfounded61
Thread starter- Joined
- Sep 13, 2018
- 17
Engine makes loud continuous beeping sound as long as key is on.. I hear a click.. but no crank.. And the connections will start to smoke on ground leads if I attempt to start it longer than a few seconds.. All leads wire brushed and battery greased on both sides..
I see a Purple wire at starter solenoid that leads to starter relay not connected at starter and I don't see a connector for it's location?
This boat ran without mishaps last season.. No one has been near this purple wire.. Puzzled?
I pulled connector from oil pressure switch and beeping stops on starting attempts.. If I touch the open purple wire to large bolt on starter.. without key on.. it makes same loud continuous beeping sound..
Any expertise would be appreciated..
