OneLuv1979
- Joined
- May 25, 2009
- 88
OK this is a 03 Johnson J115PLSTS 2 stroke. Carb Motor.
The issue is the motor starts up fine , once i give it a lil gas it bucks and shakes.
It clears up once it breaks plane and runs great. I had 3 miles of no wake and it was horrible.
BUT on the way home it seemed a lil better WEIRD!!
The boat had fresh fuel (i drained the old from the summer) new primer bulb and water seperator.
So im thinking the carbs need cleaning!
I got home and took a look at the motor to inspect how hard it will be to clean the carbs myself and i found this lil rubber tube piece on the throttle linkage that is pushed by the timing advance.
Here is a pic of what i found wrong. Im wondering if when the bad side is being pushed if this could cause any issues ...
That might explain why it ran decent on the way home , if the good side was being used, then turned to the bad side after letting off ....
I dont have a clue ,that is why im here. I would love to hear from someone who knows this parts function ....
Thanks
Thanks
