2003 Johnson 175 "No Oil" "Check Engine" and "Hot" lights come on
Matty3614
My 2003 Johnson 175 has been running great. Today I was running at 3000 rpm and the lights on the tach came on and the alarm beeped for a second then went off. The oil primer bulb was hard, and the water coming out of the pump was cool. This happened twice, but nothing stayed on, just beeps. Everything seems ok. I tightened up all of the wire connections to the tach when I got back in. The fishfinder wires were connected to the tach hot and ground posts by the last owner. I removed those. Anything else I can do?
