2003 Johnson 175 Rubber Mounts
Matty3614
I noticed two oval shaped access panels on the shaft sides of my motor. I opened them up and found badly worn and damaged rubber blocks that seam like seals.
What are these rubber mounts for?
They are 120 bucks each.....ouch.
boobie
Re: 2003 Johnson 175 Rubber Mounts
They should be your lower mtr mounts.
boobie
They stabelize the bottom part of your mtr. Can you rock the bottom end ??. If you can, post a pic.
