2003 Johnson 50HP 2 stroke - Spark Plug(s)
SkiSprinkle686
Looking to replace the plugs in my Johnson outboard. Since I am relatively new to boating, where do I find the correct plug for my engine? My dad knows boat motors so he said if I just get the plug(s) he will help me swap them out.
Vic.S
Champion QL78YC, gapped at 0.030", are the correct plugs
If you do not have a local supplier you can get them from iBoats
SkiSprinkle686
Is Champion the only brand you can buy for that motor? Does NGK not have a high quality plug?
Vic.S
Champion are the recommended brand
Engines with VRO or oil metering systems should use inductively suppressed plugs ( Q = inductive suppression)
AFAIK there is not a direct NGK equivalent BPZ8HS-10 or BPZ7HS-10 are probably the nearest ( Z= inductively suppressed)
