SS Annabelle
Thread starter- Joined
- Aug 26, 2015
- 7
Hi Everybody,
Hoping somebody can help us diagnose our exhaust manifold issues.
When we first took out the boat, she ran great!! However, we did not turn the engine off at all on that trip.
The second time we took the boat out, we sat on the water for a bit with the engine off and that is when our troubles started.
The boat runs great until you turn the engine off and when trying to start it back up there is a loud grinding noise and sounds like everything is breaking. At this point we are hydro locked (every time).
The first time we started having issues we replaced: the starter, alternator, and first New exhaust manifold. We found that exhaust manifold had a large crack in it, which would cause water to pool in the exhaust manifold, in the oil and spark plugs. Each time the spark plugs are pulled, we find the water on the Port side, middle chamber.
We also, performed a compression test on each of the 8 spark plugs to make sure there was nothing wrong with the engine itself. We found no issues with this series of tests.
Took the boat out and she ran great!! Until we turned off the engine. Once again we hydro locked.
We pulled the spark plugs (water came out of same place; port side, middle chamber), checked the oil and checked the manifold and once again... water in everything.
We assumed this time that we had a defective exhaust manifold and sent it back to the dealer to request for a replacement.
We replaced the New exhaust manifold with the second replacement. Found the same issues and hydro locked again.
This time we decided to purchase a New OEM manifold. Came up with the same issues.
We have tested the Elbow and Riser on the Exhaust Manifold and they seem to be fine. The Exhaust Manifold on the Starboard side of the boat is just fine and we have not had any issues with it. We have also found that the Exhaust manifold cracks in the same place every time. We have found this out by pouring Acetone where water would flow and putting corks in to provide a small pressure test. Also, there has been no visual indication that the boat is over heating. The gauges have all been fine and the Elbow, Riser and Exhaust Manifold have all felt cool to the touch and not hot.
So far we have replaced:
Spark Plugs
Spark Plug wires
Distributor Cap & Rotor
Replace Oil and Oil filters several times
Starter
Alternator
2 New Exhaust Manifolds along with gaskets
1 OEM Exhaust Manifold along with gaskets
Hopefully with all this information, someone could help us.
Spark Plugs
Spark Plug wires
Starter
Alternator
