2003 Suzuki Oil Warning Light
Capt. George
HELP NEEDED IN BAJA!! The oil alarm light flashing, did oil change but don't know how to reset alarm. Motor Manual in Florida and I'm in Mexico. Can't use engine until I'm sure it's just a reset problem...Engine runs GREAT high speed or low...must be reset.<br /><br />PLEASE SEND ANSWER ASAP ! need to get back to catching fish.......THANKS<br /><br />Capt. George (Retired NYC Firefighter)
JB
Re: 2003 Suzuki Oil Warning Light
What model, George? <br /><br />On some Suzi 4 strokes the light can be reset by cycling the emergency kill switch 3 times with the key ON.<br /><br />Good luck. :)
Capt. George
JB,<br /><br />Did the trick! Thank you, was going nuts, knew it had something to do with the key<br /><br />You ever get down to Baja? If you do, you got a fishing trip with me...Live in Punta Abreojos, about 100 miles from Guierro Negro....<br /><br />Get in touch if so.......muchas gracias amigo
jaybirdtx
Suzuki does this to remind you that your oil change is due.
JUSTINTIME
same thing
key on pull out the ess or kill switch 3 times within 7 seconds
