2003 Tahoe Q3 Tracker No Spark (1090412AD)
pcartwright81
First boat, still learning. Have worked on cars for most of my adult life. Picked up this boat and installed a new steering cable and ignition because they were both removed. The ignition had the wires hanging out, but I am pretty sure that I have the wires in the right position. My only confusion were the 2 M pins. Also installed a new starter relay because the one that was there was just clicking, and there was power to the bottom terminal. There was some melting that was wrapped with electrical tape, so I redid the splices with solder sleeves. Also replaced the battery with a 1000CA marine battery. After finally making the repairs the engine cranked. Most of the time it will just crank endlessly. 1/20 times the engine will catch, and die almost immediately. Any ideas or manuals would be appreciated. I can't seem to locate the service manual on the site.
Fun Times
Your shared engine model number 1090412AD makes the engine in question out to be a 2003, 90HP, [ELPTO] Model number 1090412AD.
75/90 H.P. 65 JET (3 CYLINDER)
Options:Electric start, long shaft (20”/508mm) driveshaft housing. Remote control steering. Power trim standard and oil injection standard Model style: ELPTO.
To locate a service manual part number to your engine, scroll down about halfway where it mentions service manuals in the following link,
pcartwright81
Interestingly enough this ended up being water in the gas. After getting a spark plug tester and ensuring the throttle was in neutral, and the kill switch was on had spark. Checked the gas and it was milky and green.
