2003 V6 Looper 175 water pressure gauge
mboy
Installed gauge (teleflex) but did not connect hose yet.
Read recent thread that mentions adapter plate instead of t'ing into the tell tale.
What is that about?
Should I not just be following the instructions that came with the gauge?
Also, I have removed my speedo, so I imagine I can use the same tube from speedo (and removed other end from lower unit pickup) as long as I connect that tube properly?
Water Pump was changed over winter and will be doing tstats in a week or 2 myself, so I know it is right time to add gauge.
Noticeable increase in tell tale flow over last season when I ran engine 1st time this season other day.
Dhadley
Re: 2003 V6 Looper 175 water pressure gauge
Your motor doesn't have an overboard indicator hose to T into. There is a brass plug on each cylinder head you can remove and the fitting will screw into. The speed-o tube will work but often they aren't the correct size. If it fits on the fitting and the gauge, you're all set.
mboy
Thank you.
I know it fits into back of gauge, so will see if it goes into fitting.
mboy
I am going to tackle this next week and took a peak at the engine yesterday. I THINK i saw the right fitting, but am not 100% certain.
Is their any way someone can post a pic of the correct fitting I am supposed to remove and replace with the water pressure fitting?
Much appreciated. Thank you.
Chris1956
Honorary Supreme Mariner
If you look between the sparkplugs, you should see a black painted brass hex plug. If you remove it, the fitting from the water pressure gauge will fit perfectly. Put some pipe dope or grease on the threads.
