2003 YAMAHA 225HP 4S
FreeBeeTony
Considering a boat with a pair of subject engines.
Ad says 900HRs.
Any particular issues with these years?
Not familiar with these at all.
FreeBeeTony
Went to look at the boat today, not in the water.
Can't really tell if the exhausts have been worked on or not.
Is it realistic to say if they haven't failed before 900hrs they are OK?
mike_i
sounds 50/50 chance, wouldn't give me a warm fuzzy feeling.
The 2003 Yamaha 225HP Four-Stroke (F225) is a solid motor, but there are a few key points you should know about that year and model:
Common Issues to Watch For
  • Exhaust corrosion: Early 2000s F225s were known for exhaust housing corrosion. If not already inspected/replaced, this is something to check.
  • Fuel system: Make sure the VST (Vapor Separator Tank) and injectors are clean, and check the low-pressure fuel pumps—they often get weak over time.
  • Tilt/trim seals: Like many older Yamahas, seals may start leaking and need service.
  • General wear: At 20+ years old, compression and valve adjustment history are important.
What to Check Before Buying/Running
  1. Hours on the motor (and any service records).
  2. Compression test results across all cylinders.
  3. If the exhaust housing has been replaced or inspected (Yamaha had an updated replacement).
  4. Condition of the lower unit—check oil for water intrusion.
  5. Whether the timing belt has been replaced (recommended every 5 years).
Positive Notes
  • Reliable if well maintained—many run past 3,000 hours.
  • Quiet and fuel-efficient compared to the older 2-strokes.
  • Strong aftermarket support with parts still available.
If you’re looking at one, I’d definitely recommend a professional inspection before purchase, with special attention to the exhaust corrosion issue. If it’s already been addressed and the motor’s been well cared for, it can still be a great engine.
