2003 Yami 4 stroke
Jerkalip
I am deciding between a boat with a 2003 Yami 4, or a 2001 Merc 2 stroke. I have never owned a 4 stroke. What is the comparison in maintenance and reliability? Thanks for the help and quick reply. I am purchasing this week.
Silvertip
Honorary Supreme Mariner
Re: 2003 Yami 4 stroke
you didn't mention what type of boat these engines are pushing and what HP we are talking about, and that can make a difference in my view. The Yammy is obviously two years newer, may or may not be fuel injected which is a big advantage over carbs on the two stroke. If you do maintenance yourself, costs will likely be the same but the four stroke has things such as valve lash adjustment, timing belt replacement, oil and filter changes and the seemingly never endiing issue of "making oil". A two stroke is generally a lighter engine, has better hole shot (generally), is faster on top end (generally) on identical boats. The four stroke will use less fuel. If you don't do maintenance yourself, those costs will be higher on the four stroke. I like a four stroke on a pontoon. On a planing hull I like a two-stroke (carbed, EFI, or DFI). In your case, the number of hours and maintenance records will tell the story which engine is in the best condition. In either case, insist on a compression test that you observe and by all means, do an on water test drive. Without those two, you are buying a pig-in-a-poke.
Jerkalip
Thanks for you help Silvertip. The yami is a 90 HP and the Merc is also a 90 HP. Don't know yet if the Yami is injected or carbed. Will find out this week. I fish the marsh in south Louisiana and I do need to get up on a step quickly. I usually fish shallow. The boat on the Yami is a 1997 18.6 Duracraft, 6 degree rise (modified V). The other is a 1999 Duracraft (same hull) with the 2001 90 Merc (I assume carbed). I have always been told that 4 strokes were more reliable. I'm looking for a smooth idle, reliability and low maintenance. Again, thanks for any replies.
pine island fred
Lots of shallow water around me. Made a mistake and hung a F-115, wish I had gotten a 2 stroke. Check the weight on both motors, lighter is better in my opinion. Believe you will find that any parts for the YAMAHA can be very expensive compaired to the MERC. I also have a 2 stroke MERC, both are good engines. FRED
