I was underway at full throttle after leaving the no-wake, when suddenly a constant alarm tone came on. Shut down, filled with 2 stroke oil, but the alarm continued when the key was in the ON position with the motor off. I didn't see any smoking and it didnt seem like the motor was unusually hot, so I turned on the motor and powered home with the alarm blaring. The cooling outlet operated as normal with a good pressure stream that wasn't hot on the way home (about a 30 minute ride consisting of 10 min full throttle then 20 min no-wake).
I tried disconnecting what I believe the temp sender is, but the alarm still sounds in ON with motor OFF. That sender is I believe plugged into this port typically (sensor on my motor, but plugged in this image, tan cable):
That sender was replaced before last summer's season. I plugged that sender back in and the alarm still sounds in key ON with motor OFF.
I tried unplugging what I believe to be the oil sensor, the blue and green cables shown here:
Not sure if I need to jump these in order to bypass the oil sensor alarm. Oil level is at half tank. With these two cables disconnected, the alarm still is on with key ON and motor OFF.
I should note that recently it seems as though the 2-stroke oil consumption rate has decreased, but I have no data to back that up, just instinct. Any ideas?
Thanks!
Thanks!
