2004 5.0 MPI mercruiser losing power, looking for help
achris
More fish than mountain goat
Ok, got bad info from son in law on fuel psi. Sorry.
checked it myself with new OTC gauge, ignition on pump pressures up to 40 psi and shuts off. Motor running at 1800 rpm, 37 psi. Pulled vac hose off of regulator, pressure comes up to 41/42 psi. I have read about a low psi pump prior to cool fuel system, do not see one on my boat.
serial# is om669798 if that helps. Could I install a 3/4 psi pump prior to spin on fuel filter as a booster?
Sounds like the regulator is failing...
Found this on line https://docplayer.net/46058600-Tabl...s-fuel-pressure-regulator-identification.html Had a look, and it's a great read. Plenty of good info on the regulator and pump theory of operations.
Chris........
Darwaypen
Ran with fuel pressure gauge hooked up, up to 4800 rpm pressure remained 37-38 psi. Took vac hose off of regulator, pressure comes up to about 40-41.
Did you run it until it started loosing power or any kind of popping going on?
At those pressures I don't see it being the fuel pump.
Darwaypen
No popping this time, but did lose its usual 1000rpm's after about 40 minutes of 4800-4900 rpm. pressure remained unchanged during the event. As usual slowed down putted around for a bit, acceleration was smooth, ran for about 15 min at the aforementioned rpm and lost power again. I can cruise all day long at 35 mph which is about 3800 rpm without issue, but that hard running brings something out in her. we've named her "Christine"
Guess, going to need a scan tool on the motor when it happens to see if any codes or faults show up
