TheOceanMaster
Thread starter- Joined
- Dec 17, 2009
- 2
my motor has about 500 hours on it, i ran 40 miles to the islands, and lost power and the motor refused to run. it seems like the it is not getting fuel. the motor will run if i spray starter fluid in the intake. so i replaced the main high pressure fuel pump and yet the motor still refuses to run. i did just replace the computer b/c it had bad codes in it that was causing the oil pump to run continuesly. I have feelings it is either the lift pump of the fuel system that is bad or it is the computer, other than that im clueless, any info would be great before i buy more non returnable parts that do not fix the problem.
