haley
Thread starter- Joined
- Jan 20, 2011
- 134
Greetings,
Thanks for the info. I am having a lot of fun reading through the information. I am looking at a 2004 Fundeck 170 with a 90HP Johnson OB. I'm in Rochester NY and will use it mostly on small to medium sized lakes (maybe Ontario on a calm day).
A few questions though:
Thanks so much. Happy boating.
- I am looking at a 2004 170, any worries about this vintage / hull? Sometimes there are model specific things that fellow owners know.
- It comes with a Johnson 2 Stroke 4 Cyclinder 90 HP outboard. The boat is rated for 135, so this is just under 70%. A lot of others advertised seem to have the 115HP. But the seller says that the Johnson is 4 Cylinder while some of the 115's are not. The top end may be slower but the torque from 4 cylinders may be better for water sports. Any thoughts?
- Seller says that the boat, motor and trailer weighs in at about 2700lbs. But the specs for the boat list 1200lbs. Engine s about 350lbs. Would the trailer be over 1000lbs or is he off somewhat.
- Tow vehicle is rated for 3500lbs. Trailer does not have brakes but I am thinking of adding them. Anyone have comments on this?
- It has the D rings for a tow bridal but I see some models have a pylon or tub mounted just forward of the engine. Is this as simple as adding the pole or does the hull have to be changed (think I read about reinforcing the glass).
- Anyone with similar model / year / motor?
- Can you use an aftermarket bimini or is the mounting difficult. It is an interesting floorplan.
- Kids want water sports. Wife wants pontoon floor plan. I want to be on the water. Looks like the right type of boat? Any thoughts?
