2004 Johnson 90 two stroke stalls under load when warm
odde
The engine runs great cold. But after it heats up and I turn it off it stalls under load. If I try a few times I can get it moving again and it will run great. I just have no power from a dead stop. Carbs were just cleaned and new racor water sep installed. No water found in gas on last trip. Ran it for one hour at all speeds. Fuel has been in since Feb with Stabil ethenol treatment. This is an on going problem that has costed over 1,ooo and still can find a fix. Thanks for any imput.
tashasdaddy
Re: 2004 Johnson 90 two stroke stalls under load when warm
get service manual, and do a linc n sync. also immediately check you spark, when it starts doing this. could have a coil failing.
