I have a 23 ft WA with a small cabin that has a heavy gas smell. I have replaced all hoses with no difference in the gas smell. If you take the cowl off the engine the gas smell is very strong. The motor is a 2004 Mercury 150 HP Saltwater and runs perfectly. I checked around the carbs and inside and it is dry. My thinking is the gas smell in the cowl is migrating to the inside of the boat thru the rigging tube. The boat is parked with the engine straight up and down. Has anyone had this problem or have a solution. Thanks
