colinirwin13
- Joined
- Jul 28, 2017
- 2
Hi there
I have a 75hp 4 stroke from april 2004 (salkt water). It wasn't used for almost 2 years and serviced before used this summer.
Now the engine starts fine however if there is any slight change in the angle of the boat (If i move from front to back, or if i adjust the trim by even 2 degrees) the engine splutters and dies. It sounds lie it is being starved of fuel.
If i persist and get the boat up on a plane - after a few efforts - the engine will run at full speed but splutters and drops revs occasionally.
I took out the plugs and they look a bit fouled. I drained and washed out the carbs with petrol and sprayed in some quick start and wd40 to see if they would loosen things out, but no improvement. I was using fresh fuel and tried running of a separate tank with the same result.
Does anybody have any idea what could be causing this or has anyone experienced the same?
Thanks
Thanks
