83Evinrude
Thread starter- Joined
- Sep 3, 2008
- 290
My 2004 SX-M outdrive has been failing to shift into forward some of the time.
On advice from a response to a previous post (apparently lost on the vBulletin upgrade), I checked the following:
Disconnected the shift cable under the outdrive cover, and found the cable has 1/4 inch of free play. Is this too much play, or is it ok?
When I manually move the shift bellcrank arm, I get positive detents at neutral and reverse, but forward doesn't detent as well.
I manually shifted into forward then adjusted the cable nut to match the arm it connects to, and the nut is almost out of adjustment on that end.
This adjustment results in the remote control moving the bellcrank arm fully into the forward position, but it lacks just a bit of fully reaching the reverse detent.
Also changed the lube from Valvoline synthetic to Volvo Synthetic gear oil.
Went for a test drive and all shifts seemed to work fine, but the way the bellcrank feels when shifting into forward with the cable disconnected has me worried.
I'm wondering if the shift cable should be replaced, if so are these universal or specific to Volvo remote controls?
Do you just remove and measure it for length? Any good aftermarket versions available and if so where to get one?
Thanks
Thanks
