2004 Tahoe Q4 sf /w 3.0 Mercruiser: Prop & Smart tab questions
Cap'n Bigcat
Prop : boat currently has a 3 blade aluminum, 13 3/4 inch diameter with 21" pitch. Not sure if this is the correct prop since boat was purchased used. Can anyone recommend correct prop size/blade number/pitch combination that optimizes perfromance? Typically towing a skier, two kids tubing or fishing with 3-4 adults on board. Want to get a better hole shot for skier and be able to come to plane faster.
Smart tabs:anyone installed on this/similar boat and what are your results?
dhendersonm
Re: 2004 Tahoe Q4 sf /w 3.0 Mercruiser: Prop & Smart tab questions
See mccownk's post below. It's got all the info you need on the Smart Tabs SX installation on your Q4.
rdhawk1950
Factory specs for that prop for that engine is a 14 1/4 x 21. The larger diameter would improve the hole shot. There are try before you buy props available thru some dealers and maybe even Bass Pro Shops.Check your area via internet.
Cap'n Bigcat
Thanks for the clarification of the prop specs and the try before you buy idea.
