2004 yamaha 4 stroke 150 hp
dbarker
My engine has started smoking at idle and excess fuel is dumping out the exhaust. I removed the spark plugs after running at idle for a few minutes and #4 spark plug is wet with fuel. Engine seems to be running smooth maybe a little rougher than normal...
Any ideas what might be causing this problem?
Thanks
timster
Re: 2004 yamaha 4 stroke 150 hp
Have you checked for fire on the #4 spark plug??
dbarker
I have fire. I wonder if it could be the vapor recovery causing the excess fuel being released in the exhaust?
rodbolt
most likly an injector leaking,a VST needle valve leaking or a bad pressure regulator.
vapor canister wont have anything to do with raw fuel in a cylinder.
dbarker
Thanks. I'm taking to the dealer.
