2005 115 Optimax oil consumption
butlp
My 115 hp Optimax has run great and still does, however this year it is using way more of the high priced Mercury synthetic oil than previous years. The only changes this spring were three new plugs and new accessory belt. After changing the belt I revved the motor in idle and it hit the rev limiter and the alarm briefly sounded. Since then the alarm has sounded a couple of times when the engine first starts and once when skiing at 3500 rpm. In all cases the alarm only sounded for a few seconds.
I think the motor has been using oil at about 25:1, but it does not seem to smoke any more than in previous years and there is no evidence of an oil leak under the hood.
The motor still seems to start, idle and run as well as before but at C$80 for 4 litres of the optimax oil its starting to get expensive.
Anybody have any ideas?
Bifflefan
Re: 2005 115 Optimax
could be the auto oil system going out.
is it under warranty still?
if so take it in, if not, id still take it in. motors cost a lot these days.
butlp
No its not under warranty and I?ve talked to my selling dealer about getting him to check the computer fault codes. Unfortunately he is a couple of hours away and I'm in the middle of vacation.
