2005 175HP VINDICATOR
FreeBeeTony
Too bad......saw a pair for $5K w/ Rigging. They're grey.....some kind of military edition?
FreeBeeTony
Anyone familiar with this Military edition?
Also have read that the issues may have been solved by 2005?
If it is the military version it is the same motor as what you are struggling with.---A 60 degree carbureted looper.
Is it labelled an EVINRUDE or JOHNSON-----Post as much info as you can.-----Incomplete info just leads to confusion and misinformation.-----The info I see listed for a 2005 military model shows it as a Johnson carbureted 60 degree looper.-------What is your information if any , telling you what it is ????
The E makes it an Evinrude.-----The F makes it a direct injected computer controlled motor.------You would need BRP / Evinrude dealer support at $100 + / hour for service work.----Might not be easy to find a shop to work on it.
Best to call your local BRP / Evinrude shop for an opinion.----Also look into availability and price of some parts too !!
Why do you say ----" not E-TEC " -----about these motors ?????-----Johnson marketed carbureted 175 HP modeld in 2005.----The model # posted indicates a 2005 EVINRUDE.
There won't be any -----" Freebee " ----- service and parts available for these in the near future.----The motors you have now are elegantly easy to repair , trouble shoot and maintain !!
FreeBeeTony
I understand it's an Evinrude not a Johnson.
Just wondering if it's considered an E-TEC, that's all.
Is an E-TEC not considered an Evinrude?
dingbat
That serial number (F) says no…..Ficht.
E-Tec technology is (D)
dingbat
What's your opinion on these engines?
Now that BRP (Evinrude/Johnson) is out of business either is a viable option IMHO.
Tried of burning thru $90 worth of oil with each tank of gas.
Upcoming re-power, if I don’t just sell the boat flat out and replace, is either a Yamaha or Suzuki 4 stroke
FreeBeeTony
I assume you NEITHER is a viable option........
tphoyt
Personally I would stay far away from a ficht. Some people have had good luck with them but most have not. Parts are hard to find and you will likely need parts on a regular basis. It was just a crappy technology.
