2005 25hp 2stroke
benzico
hello ,my outboard seized,damage to big end bearing and cylinder scored and seems to be coated with alluminium,i think from the piston .my question is can i rebore this block and fit an oversize piston to this model.the block seems to be a single piece,should the head come off because i cant see any sign of a gasket or join between the block and the heads of the cylinder.the serial number on the block is OP359985.i do not have a workshop manual for this model but i have worked on an older one and the head and block were separate items.thanks for any help. ps i live on an island in the atlantic with no merc dealer.
corm
Re: 2005 25hp 2stroke
Hi,
I am not sure you can do that. I do not know for sure on the 2005 engines but the older ones had chromed bores and could not be bored unless you steel sleeved it.
I hope some one knows more than me about this.
^bump^
