spunkyman
Thread starter- Joined
- Jul 17, 2011
- 153
Hi all...
I've been slowly creeping toward getting my boat running.. with new long block, MAP, IAC, Temp sending unit sensor 806490T and Water temp sender 805218T
(both sides of thermo housing) and every other sender/sensor , NEW smartcraft gauges - I still get error saying - WATER PRESSURE SENSOR
I've recalibrated the Tach Smartcraft gauge and still getting the error PLUS these other 3.
- Trim position sensor
- Pitot sensor
- Fuel level sensor
Also, My oil is reading 82 PSI at key turn - not running. I fire her up and still reads the same. Reset smartcraft gauge, same. I unplugged sending wire and still reads same high PSI. The gauge is new, the sender is new. If it's a bad ground, is there a quick fix or does it ALL have to go through the ECM somehow?
I've read everything I can to try and sort it out, all over the forums and tried those fixes.....
many thx in advance...
- Pitot sensor
- Fuel level sensor
