2005 350 Mag dropping fuel pressure under load
Fun Times
At the end of the day, nice job in your diagnostic testing done.👍
Scott06
Update here. There was a 1/4” drill socket used to plug the line during repower stuck in the line. I’d call that a fuel restriction LOL. I’m going to test tomorrow as the north wind was howling today on Lake Huron, gotta think that was the problem. No idea if I or a helper shoved the line on with that fitting still in there. Ridiculous!
Always the simple stuff . Great job finding it
jrglombo
Second update - no more fuel problems after several trips out. But my ignition kept getting killed again. Checked my wiring again and I started to check move the wiring around towards the coil pack and when I moved the spark plug wires around engine stalled and beeped like you just turned the key off and back on. If I put some rpm to it at the dock and moved the plug wires towards CAN line it would do the same thing. I had the old set of wires still (mercruiser brand) and I put them on that side of engine and rerouted CAN line to not be near plug wires. YIKES. What a crazy thing, I’m hoping my new set of plug wires was bad, but have read and was even told here that plug wires can do some weird stuff.
Thanks for the update but I'm not seeing how plug wires will kill a motor unless its burning thru the jacket of receiving wire
Might be loose/corroded connection on the engine connector
