soonerborn1
Thread starter- Joined
- Jul 19, 2010
- 18
Bought the boat this year, the boat starts and runs fine but when I shut
down and sit for a bit, when I start the boat the engine runs rough then dies.
After sitting for a while letting the engine cool down, the engine will start and run fine again. If I shut down after running for a while and then start right away, its fine. Only if I let sit for 30 or so minutes do I have the problem. The pump is priming when I turn key but there is a different sound to it when it finally starts and runs good. Is this a vapor lock issue?Could the pump be going bad? I have changed the filter and fuel pump relay but did not fix.
