I am endeavering to start working on my own boat and have the following questions. Any support is appreciated.
What is the solenoid and reset button next to the caburator?
Where is the nuetral safety switch located? 2005 234 tahoe.
What is the little bugar next to the bilge pump directly under the engine?
Is there another solenoid for the starter other than the one on it?
General starter wire connections: There are alot of wires that go to the starter. I am used to a main power and one to activate the solenoid, but there is another one on the solenoid also. I think it sends power to somewhere else or maybe is a secondary needing power also, maybe from one of the above items. But when I had the starter out I am pretty sure I tested it with just the one solenoid connection.
How can I turn the engine over manually. It says it is a left handed motor, so if I turn the bolt on the crankshaft pulley will it just losen and if not could I brake the bolt with to much force. I have already losened the bolt and tried it the other way with a breaker bar.
Thanks again for support
