I have a 2005 Yamaha F150 outboard that I recently brought in for servicing. The dealer noted a stray voltage that he traced back to the motor. He was reading 386 mV even with the batteries removed. He suspects it is related to the stainless steel prop installed on the motor. The potential was removed by running a ground wire between the engine block and the hull of the boat. It now reads 0 V.
I have a few questions related to this:
1. Should I remove the stainless steel prop and replace it with an aluminum one? Can an aluminum prop be run on these engines as I have heard from different people that you have to run stainless steel?
2. Is this a common thing to have potential created by the outboard? Is it related to the stainless steel prop, and if so what creates it? If it is not the prop, what causes this?
3. The dealer indicated that if left uncorrected, it could cause other electrical problems, shorts, blown fuses, shocks, etc, and possibly corrosion and paint issues. Is this the case or would it require higher potentials than the 386 mV measured?
Thanks
Thanks
