Texasbikers
Thread starter- Joined
- Sep 12, 2007
- 21
Hi all, have a 2005 Ebbtide with 2005 Mag 350 MPI, Engine serial # 0W320266. 325 hours on engine now, this is the first issue I've ever had with it.
Had issue with it idling after being run for 30+ mins, wouldn't idle, wouldn't start etc... I did replace the IAC at 320 hours of engine time along with the little filter in the TB, it ran great, no issues until yesterday. Back to the same issue. Normally I hit the key and it fires right up, yesterday, when it was cold I had to crank it a lot to get it to start. Once it started it ran great, we ran across the lake 30 mins, did some wake boarding, ran perfect.
Pulled up anchor after sitting for 2 hours, started fine, idled out of the cove and while sitting still, in neutral at idle for about 3 mins, the engine slowed down, stumbled and died. When trying to start it it would start, run about 400 RPM, couldn't get it to rev up or keep running, died. Over and over again tired to start it. Tried throttle at 25%, 50%, 75% WOT, nothing helped. I sat for about 15 mins with blower on and engine hood open. It finally started, ran great, I didn't let it get under 1,000 rpm until I docked it. It is weird to me that it wouldn't start, over and over trying, then all of a sudden it starts right up and runs perfect.
So, any ideas what might be going on? I did use a Sierra brand IAC replacement part #18-7701. Any chance it went bad in 5 hours of run time?
Thanks everyone.
Thanks everyone.
