robbrownatc02
- Joined
- Aug 28, 2009
- 5
I have a 2005 22' Maxum with a 5.0 Merc. It is docked in salt water and rarely used for a few months. I am using it more now and it is overheating. It seems to always run a little hot, about 175 and at times the alarm goes off. Slow speeds and wakeboarding, starting and stoping it does ok. Sustained speeds at 3000 RPM the temp rises to 200 until I release the throttle and allow it to cool down. There is water circulating in the system and the problem seems to be getting continuosly worse. Where should I start replacing things? Where could there be a blockage from lack of use? Thermostat, elbows?
