bobmk
Thread starter- Joined
- Jun 19, 2010
- 12
My 2005 Mercury 50hp's oil injection tank is leaking thru the switch assy on the bottom of the tank. I removed the switch assy and found nothing to seal the switch (probe) to the tank. Tried adding an O-ring to the switch with no success. Looked up the parts diagram and didn't see any type of seal for the switch.
I noticed oil dripping from the lower unit when I had the boat in the garage and traced it to the oil tank. This just started leaking on its own as no work has been done to the motor recently.
Thinking of buying a new tank as one of the top mounting tabs on the tank are broken and the other is cracked. Don't want to shell out $120 for a new tank and have the same problem.
Any ideas?
Any ideas?
