2005 Mercury 50hp 2 cycle surging under power
lszet55
Thanks for reading!
Driving the pontoon at 3k rpm will drop to 2k then back to 3k then to 2.5k and so on. I pump the ball and the rpm will stabilize. I have replaced the tank primer ball and fuel pump. Also pulled the fuel pickup and it was spotless, Carburetors have been rebuilt twice by two different boat mechanics. The pontoon has never run right. It seems to be starving for gas or running lean. Any ideas on what could be causing this condition or what to check next.
lszet55
Seam to be misfiring or just not running smooth. I replaced the line from top cylinder to fuel pump.
lszet55
it will stop surging when I pump the ball. Like I’m forcing gas into the carb bowls?
lszet55
JimBo I’ve replaced 2 fuel pumps pulled the tank outlet tube replaced the primer ball checked the fuel line connector at the motor, replaced the fuel line to the pump. It seem to still be starving for fuel?
dwitting87
I wonder if the fuel pump is not actually running, i.e is the air line to it actually moving the diagraphm. I have no idea what typically fails on these types of motors, but I would start with fuel obstructions (assuming you've already confirmed the rebuilt carbs are good) and then move on to fuel pressure related issues (i.e. is the pump actually be actuated).
dwitting87
maybe one option would be to unplug the air line and see if it's actually working with or without it. Keep removing suspect parts/functions in and out of the equation.
lszet55
I took fuel line at carb off and cranked it. It’s pumping fuel not a crazy amount but pumping fuel. I looked for a volume but could not find anything
lszet55
Dewittng 87 there are two inputs to the fuel pump one from the upper cylinder and one under the pump itself from 3rd cylinder not sure what you mean. Your saying remove the line from top cylinder?
There is compression in the cylinders.----What are the actual values?----There is compression in each crankcase.-----It is compression pressure in the crankcase that drives the fuel pump.-----There may be a lack of pressure pulses in the crankcase.
lszet55
I was wondering if crank seals could be leaking messing with the mixture in the crank?
QBhoy
I know nothing about pontoon boats (don’t get them here)…other than overwhelmingly so…I seem to be constantly reading on here about their absolute requirement to have the engine set up extremely accurately…and then even at that…they have a habit of gulping air or not staying hooked up at the prop. You sure it’s not maybe doing this ?
lszet55
The prop is not in good shape. I question if the prop could be cavitating. But at steady speed rpm goes up and down, once it started to cavita I didn’t think it would stop?
