bluechevyy
Thread starter- Joined
- Oct 23, 2009
- 52
Please help! I have a 2005 mercury 9.9 4-stroke with electronic ignition, power trim, yada yada yada, all the options. I can not for the life of me get my kicker to run properly at idle. Currently it will start with the choke on revs up high and then dies. The only way I can get the motor to stay running is standing at the motor and feathering the throttle.
Thus far I have tried the following; I have pulled the carb out and completely disassembled and cleaned all parts. The jets and all are clean. I replaced the seals in the carb and reassembled it. I do run stabil in my gas year round and have checked the fuel which is clean and free of water.
I have replaced the fuel line/primer bulb with a new one to verify I'm not pulling air into the fuel system. I have changed the fuel filter ( I did use a more universal filter that I could see through which is slightly larger vs. the original).
I spent much of yesterday messing around with the idle screw and have uncovered the fuel mixture screw to adjust that. Still no luck.
What I have is a motor that will start up and run only at extremely high rev'ing speed. If I attempt to back off the idle screw setting it idles down and dies. Also, it will adjust speed by itself. I will just get it to start running at a slightly lower idle and it will rev itself up very high.
The only thing I have noticed that doesn't seem right is the fuel filter seems to empty slightly while running (does not stay full).
Please help a.s.a.p. as I am suppose to be taking my 3 little girls to Hagg Lake for the opener today. Unfortunately, I cannot afford to take this to the shop. I am fully capable of all repairs on this myself, I just need help figuring out what is going on.
Thanks so much!
Curt
Thanks so much!
Curt
