2005 opti 150 towing
jtcnj
I see Mercury didnt bother with tilt support trailering bracket like my old Johnson has. If i think i have enough ground clearance, think it is ok to trailer at the end of the trim range, where the housing is in contact with the trim posts, not in the higher tilt range where all the weight is on the ram???
tashasdaddy
Re: 2005 opti 150 towing
any tilt the weight is on the tilt system, get a transom saver. take the pressure off the transom.
