2005 tohatsu 70 hp running issues
123dggregory
Hi,
My Tohatsu 70 hp is having running issues. It seems to be only running on 2 cylinders sometimes or have a complete lack of power. It will then pick up and then go back to poor running (quite quickly like your are tapping the throttle)
It does occasional work properly for longer periods, then poorly again.
Im thinking it maybe plugs, HT leads (if it has them) or a dirty Carb
Can anyone suggest what is more likely? Im thinking a dirty carb would be more likely to run badly all the time so its probably electrical??
Thanks
TOHATSU GURU
Re: 2005 tohatsu 70 hp running issues
Could be either, but...The way to determine the problem is by getting out the service manual and eliminating possible problems. Or you can just clean the carbs, correctly, and you have a 90% chance of curing it.
pvanv
What is your model? Is this a TLDI? If so, there aren't any carbs... and the onboard diagnostics should tell you what faults are being detected.
fishskiff
123dg, my honda bf15 had similar symptoms when the ignition module failed. I ran the engine at home on the hose and while it was idling i tapped everything with a screwdriver handle. when i tapped on the cdi/ignition module the engine died and would not start. This is after new carb plugs etc. that didn't fix it. hope this helps.
pvanv
Nice to know... but you have a completely different motor, from a completely different manufacturer, so odds of the OP's problem being addressed by your information is remote at best.
