The past two times I have taken my boat out I have had problems with idling.
Here is whats going:
When I first start it in the morning it idles real rough.
Later in the day when I would pull up to a fishing hole and place the engine in neutral the motor would die.
When I crank the motor back up it was hard to start and would die quickly if it did crank.
I noticed if I put then engine In Gear real quick it would idle normal.
Well afterthis lol I got it to start up and it idled but it sounded like only 2 cyliders were firing or as if it was missing. When I put it in gear every thing was ok.
Then at the end of the day it idles and purs like a kitten ... perfect
All day the motor runs great in gear running at any rpm range.
All the filters have 50 hours as does the power head and plugs.
I checked compression with some cheap rent a tool gauge from autozone
All cylinders were at 110 115 range.
Any ideas?
The motor run great other then this.
Any ideas?
