Havasu bound
Thread starter- Joined
- Jun 8, 2011
- 17
Ran great last fall when test driving. Over the winter we changed fuel filter, put stabilizer in fuel tank. Did a carpet change so everything including one tank had to come out. Put all back together, put in water and under load ran up to 3000rpm then sputtered, backfired. Like starving for fuel. Runs fine at idle. After minute or two it will run back up to 3000 rpm for a minute or two then start the sputtering all over again. Not an engine guy so took to dealer. They put on computer and found no codes. So they put on water to experience issue. They put back on computer and again found no codes. Think it may be "mapes sensor" ( not sure of spelling). Does this make sense? Or should something else be obvious or checked? Guessing is something I do, not sure dealer should be using this route. Any ideas or thoughts? This is a pontoon boat with 190 hours.
