2005 yamaha F115 loss of power
fishinvet
Hi
I have an 05 4 stroke Yamaha 115 powering an 18' campion. On Thurs nite after refueling, the engine wouldn't make better than 3800-4000 rpm (WOT 5500 rpm)
No alarms, wasn't dragging anything, prop/plugs/oil level all looked fine, engine wasn't misfiring etc. I tried adding some injector cleaner but no improvement. The area I'm running in is very sandy/shallow in some spots but water flow from the engine seems good. Replace the plugs first?
Thanks
Ray Neudecker
Re: 2005 yamaha F115 loss of power
If you have a fuel water seperator, that would be a good place to start.
fishinvet
Thanks folks
The fuel filter and water seperator checked out OK. Any other thoughts would be appreciated.
Ray Neudecker
Did you change the filter? It certainly sounds like a fuel restriction problem.
